RE: Shockwave 55 gel coat and repaint??
No need to glue the tube into the stuffing box just slide it in,the tube is then fixed at the motor end using a t bar or home made holder.That way should you ever need it out it will just slide right out once released from the t bar.For powering your reciever and servos use a nimh hump pack 6 volt.
Mart
