RE: DBC/DBU2 problems, need advice(fixed)
I don't own a DBC so take that to heart but,<div>does the DBC shut down the tank if you move the stick all the way up when it is running?</div><div>it appears to me that shutting off the tank with the power switch is possibly leaving a charge on the system and the electronics are hung up in a loop or they are in the middle of an executuion. It takes a while for the charge to leave the system and that is why you can restart the next morning. </div><div></div><div>Like I said I don't have a DBC but that is what it appears to be.</div>
