RCU Forums - View Single Post - Robart Pin Hinge Question
Old 07-15-2012 | 05:13 PM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: Robart Pin Hinge Question
I don't grease on mine, but i use Gorilla glue. I put a small amount in the hole and spread it around the inside of the hole with a tooth pick. Then I spray a little water on the hinge and insert it. It only takes a small amount. With a little practice I found this much easier than epoxy and less messy. Some of it may squeeze out the top, but can be picked off about halfway through the drying process. I don't clean or sand the hinge point prior to installation.
David
