ORIGINAL: aerobear
ORIGINAL: rmoose
One would think by the time you get to level in this hobby. a prop would be the least of the exp.$ and besides id never trust a nylon apc on a big engine why distroy yourself and the airplane when is either breaks or comes off at you. thats why they have all those bolts holding it on the hub to start with.? Have you ever seen a prop shatter not very cool... im not talking crap just giveing the facts
The amount of money spent is irrelevant. APC makes props in sizes and pitches that are not common in wood props, especially for pattern plane use. APC props work great on the YS engines which are in the same power neighborhood as a 35cc gas engine. The multi bolt hubs on little gas engines are there so you can get that big boy look on a little engine. They are not needed in this size engine. A single bolt hub allows the use of ANY prop so it would make more sense than the multi bolt setup which creates a pointless limitation. I have used APC since they first came out. Never had one shatter or seen anyone else shatter one.
One the other hand I have seen plenty of guys break the bolts on a multi bolt hub. I don't blame the hub though, user error.
ABear,
Exactly!!
BTW- The piped OS33GT I'm using on my pattern plane turns the apc 20x10.5 and 20.5x10 props the same as the YS175 does, on "cheap" petrol. No expensive 30% heli glow fuel for me. I also have tried the 19x11 and 19.5x11.5. The 19x11 also was terrific match, but not the 19.5x11.5... juuuuust a bit too much
The soft mounted engine produces nearly electric like quietness. Terrific thrust output particularly in mid range where many gas engines have faltered.
If the DLE35RA matches that performance, it would be awesome! One more thing, guys please don't use the really large props right off on the DLE. I broke the OS in on a smaller prop (18x12) for about 4 gallons before going up in load.
