RCU Forums - View Single Post - Help with something I have never seen
Old 07-16-2012 | 10:50 AM
goirish's Avatar
goirish
Default RE: Help with something I have never seen
ORIGINAL: Mr67Stang
Hey GoIrish, we need a little more info. Do you have the servos on a Y-harness or are they plugged into seperate channels of the Rx. If it's the second option, which channels? Are the servo's orientated the same (output shafts both towards the trailing edge of the wing or both to the leading edge? If they are not the same, that's the problem.
Using a Y-harness. both servo arms are facing outbound. both servos are mounted so the output shafts are closest to the TE. Actually like all of my other planes.
