RCU Forums - View Single Post - OS BGX-1 Glow to Gas Conversion (Yeah!) Thanks Max
Old 07-16-2012 | 11:52 AM
  #35
Broken Wings's Avatar
Broken Wings
My Feedback: (20)
Default RE: OS BGX-1 Glow to Gas Conversion (Yeah!) Thanks Max
ORIGINAL: irocbsa
I'm guessing that the crankshaft on the glow engine is not hard enough to accept a roller bearing. We would need to get data on the Rockwell harness of the material the crank was made from.
The shaft hardness must be Rockwell C59 minimum and a maximum roughness of 15 microinch AA.
http://www.maintenanceresources.com/...ings/rbshf.htm
If you had to change the crank pin....A good machinist and a gage pin the size you needed would do the trick.
