RE: Robart Pin Hinge Question
i put a very very small dab of vaselin on the hinge area as I like almost zero gap. I also use expoxy to secure them letting 3 or 4 drops drops fall in the hole off the end of a tooth pick. The key is to ensure the hole is not longer than the hinge point but matches it so the is then forced up around around the barbs.
