Sounds pretty good. A little on the expensive side considering you can get Ultra Xtreme High Solid Clear for about $74. a gallon with a qt of activator. Mixed with the proper amounts of Reducer and Activator they make about 1 1/2 gal. It needs to be reduced to a 4 parts clear and activator with 1 part reducer.
This is one of the best clear coats I have found. Only other thing you need is Reducer . I have personally used this and I like it.
http://www.paintforcars.com/clearcoat_xtreme.html
Here is what they say about it:
<font size="-1" face="Arial, Helvetica"><font size="-1" face="Arial, Helvetica">For the Ultimate in base coat clear coat automotive finishes, use Xtreme Urethane Clear coat with 1 quart Activator. This true "whitewater" Urethane Medium Solids Clear Coat offers the highest durability and gloss as well as UV protection against fading. Flash dries with activator in only 10-25 minutes.
Urethane Clear Coat offers very high hardness for the ultimate in durability. Can be applied over any single stage or base coat auto paint. Ultra Xtreme Urethane Clear Coat dries to an incredible gloss with no buffing. Mixed with activator 4 to 1 ratio. Compare and save. You can't beat our prices for clear coat and auto paint supplies.</font></font>
Frank
