RE: JET LEGEND VIPER BUILD THREAD
All understood. On my mix it works fine with servo's or Jet tronic valves so my mix is proven to work ok.
The problem is that when the switch goes to up or inhibit the valve in this case, the valve goes to full on instead of killing it no matter what I do.
I suspect its got something to do with the electronics in the JL valve system, are you using the JetLegend valves?
I'm going to play with the combo now!
