ORIGINAL: micah11
I fixed the temp. issue. Bad battery connection. It looks like I lost a lower spring retainer on the front right tire while driving it. Can I lightly run it around on pavement until new shocks come, or will that hurt the spring?
it will be fine like that, the spring will just not rebound as good. when you get the new retainer, put a drop off crazy glue on it at the shaft. also it's not a bad idea to spray those retainers with a bright color so you can find them easier if you lose 1. same goes for your dogbones
