RE: Help!!!!! I have a DX6i problem that we cant figure out.
Since all works well when you plug the battery directly into the receiver then the problem HAS TO BE The SWITCH AND/OR THE WIRING BETWEEN THE BATTERY AND THE RECEIVER. That is the only difference between the working and non working setup. Check the connector that is wired to the battery as that is one of the connections in the NON Working loop.
