RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Yah. I have this 20 on a spacewalker 2 but as usual keep the cowl off for the first couple of tanks
Running rpm is less than 8k at full throttle and slightly less than 2k at idle
Yes it is a bit rich
Is there a way to test the ignition under load?
Battery voltage after it quits is just over 5v so I'm pretty sure the battery is doing the job
