RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 07-19-2012 | 05:45 PM
  #5591
phakur
My Feedback: (13)
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Everyone I certainly appreciate the advice and ideas and I know it is kinda tough to troubleshoot without being here
Let me say a little more
The guys at the field know quite a bit about dle engines but as always can learn more
The cowl has never been on the plane other then on the workbench to make the cuts. The guys at the field won't let me fly with cowl until at least two tanks thru the engine. The screw settings on the low side were changed and then changed back the high side was checked and never moved So I don't think overheating is the issue but Can't rule it out.
I have been told that the carb can be rotated by folks on this forum and I dont know but suspect the engine wouldn't even run if the carb wasn't doing its job. At least partially. Of course. Who knows for sure
The engine runs fine for the time it does and then it just cuts out. Just like I threw the cut out switch
Its like No fuel. Or no ignition
I think I have eliminated fuel draw out of the tank
Wondering if the carb is messed up somehow or the ignition is quoting after working a while
Just want to thank everyone for chipping in and trying to help
All comments are appreciated
Larry
