RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 07-19-2012 | 05:56 PM
  #5592
ahicks
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
ORIGINAL: phakur
The screw settings on the low side were changed and then changed back the high side was checked and never moved So I don't think overheating is the issue but Can't rule it out.
Larry
Larry, has anyone really adjusted this carb (adjust HS for max rpm, then set LS for good transition), or are you/they trying to run it on the factory settings? -Al
