RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Yeah. We opened the low a bit to make sure we could get fuel into the engine. It being new. Didn't go much in the high side other then checking rpm. I think we gave it less then a quarter turn. The engine runs great for the several minutes in runs. No hesitation no stuttering. Up until the second it just quits Moved everything back to factory setting in an attempt to clear the problem
I'm using lawn boy oil mix so we are seeing a small amount of deposit out the exhaust as you would expect
It's just kind of wacky
I'm pulling the engine and will have the guys at the field take a look at the carb this weekend but still don't know how to eliminate the ignition as a possibility
