Hope it holds for ya...
Im gonna try to post pics...if it works, i will add descriptin...
Had to add balsa on wingsaddle to get the wing aligned with H stab. It will be done nicely, those are test spacers .
The rear of the wing will also be blended in.
The engine compartment has been built up...it was totaly open like an old trainer, on the sides and top.
Wingtips were squares...I rounded em off, and I will final sand em here shortly.
You can se under the nose where I added a long thick block. Before, there was a flat bottom all the way to the spinner ring....that 3as wrong so I am sculpting a new front end.
On the turtledeck pic, you can see some paint still needing removal....gawd....this thing had so much paint, wasnt even funny...
Lat pic, you can see how round Im gettin it, as it was a big square nothin to begin with.
Hope you like it!
