RCU Forums - View Single Post - Goldwing 50cc Pitts Python V3.
Old 07-23-2012 | 07:20 AM
  #116
Mustangman40
Default RE: Goldwing 50cc Pitts Python V3.
ORIGINAL: scale only 4 me
Running a 22-8 on the 55
<span style="color: #ff0000">I'm running a Power Expander Pro so no "Y"s are needed. it has Battery share and regulated 5.0 volts to RX built in and I use the pin switch option. running 2 a123 2300 cells, 2000 mah niMh pack for ignition, Rcxel optikill switch,, no other regulators needed with this set up.
5625 servos for the Ailerons, Running left side chn. 1 right side chn 7 , using the Aileron differential in the Futaba TX, Servo were matched via a Hitec servo programmer. Elevator servos are Programmer matched also. single 7955 for Rudder
</span>
CG is where the manual said,, as much of a joke the manual is, it seams to fly well at that point.
glad to be of help, good luck
Wow,
your set up is just like what I am gonna use, who would have thunk it, glad I thought of it first....
The more I read and think about it, the more it makes good sense to use the Power Expander, just to many positive things about it not to spend the money.. I am going to get the Pro as well, with not having to buy other things, the cost is pretty dang good for what your getting... I am on a budget nowadays, union carpenter and work just isn't what it use to be thanks to this economy and agreedy union pricing us out of work.
Plan on working on the cowl today, don't have to work till tonight, I will keep you posted on it.
I picked up a EDF F-20 tigershark and did the maiden yesterday.. What a hoot that little sucker is, screams louder then the wife and is much more fun..
