RCU Forums - View Single Post - Spinner nut falls off
Old 07-23-2012 | 11:14 AM
opjose's Avatar
opjose
Default RE: Spinner nut falls off
Ibid...
If it's coming loose, you're wood is compressing, or your not tightening the nut enough.
Every time I see this happening to someone, I pull out a larger wrench than what they have on hand and REALLY tighten it down.
The standard response I get is "aren't you afraid of stripping the nut?" but their prop nut no longer falls off.
The double lock nut is a good safeguard, particularly for wood props, but it shouldn't be needed for composite props.
Locktite? No thanks! I already have problems getting locknut off.
