RE: Como .50
Another way as stated on the supertiger carb instuctions is to remove the carb and screw the idle needle in until the needle is halfway across the catseye opening and to make sure the catseye is pointed straigh down the barrell. That is the starting point. After you get it tuned, you can turn the catseye slightly to the side either way for good midrange. That is how I did my como 90.
