RE: Extreme Flight Vanquish 2m Build Thread
Another way to look at the problem: most of us that are posting have the stabs set to 0 deg incidence anyway. I do not recall anyone posting that they change stab incidence once set to zero. That said, perhaps there is another way to fix the stab without using the adjuster set screws? Is it possible to get the correct incidence on the culprit stab and lock that in with an "L" bracket or two under the stab? Am not near the fuse at the moment so just thinking outside the box a bit. Hope this helps.
