RE: I could not resist...
Another point that you may already know but I'll refresh anyway; Once CA hinges are put in and the CA is applied it WILL NOT wick the CA back over the hinge again, the wicking is completed on the first shot.
If you feel that there is a problem with a hinge try making a small hole over the hinge ( both sides ) and squirt some glue in that way and see if it tightens the hinge.
The best way if you suspect a hinge is to drill a small hole through the hinge , push a round tooth pick in the hole , trim it off, then put thin CA on it. Then either cover the hole or paint over the spot .
ENJOY !!! RED
