RE: Unexplained loss of control
BTW is is a big chaos from bridi with an OPS 30 running gas.
I installed a CRRC Opto coupled BEC cut off unit for the ignition. All of the extensions and y-harnesses will be replaced. The RX is velcro mounted on a piece of lite ply which is mounted to the fuselage with a piece of foam in between. This makes a soft mount.
I ordered an 8FG super today.
I was playing with it today and the ailerons were not working properly. It was a programing problem. I had flown the plane several times before. I checked the control surfaces before flight. Maybe I missed the ailerons being reversed???? Gads I hope not, I am a bit young for such issues.
Thanks for all of the great suggestions.
Scot
