RCU Forums - View Single Post - Goldwing 50cc Pitts Python V3.
Old 07-25-2012 | 10:23 AM
  #117
Mustangman40
Default RE: Goldwing 50cc Pitts Python V3.
Every once in a great while, we come across a product that makes us say WOW! Well I found my wow product with Ezekote resin...
This stuff couldn't be any easier to use and the results are awesome. I gave the whole cowl a coat like the directions say, let it dry for the 20 minutes it says to and sanded it down for the next coat.. Does it sand like a dream and filled all the little pits fromcrap paint job that i had to go over.. Then I applied the glass where I wanted it and brushed in the second coat, it recommends 1/2oz cloth. all I had was some 1.5oz and didn't feel like waiting to order, I also wanted to stiffen up the top of the cowl where it was weak and cracking, so I went with it... I know you cant see it in from pics, but it's awesome, smooth as can be. After the glass coat dried, I cut all the extraglass with a sanding block and feathered it in where I stopped it.. I did this so that the last coat would help fill the transition and it worked out great, no filler needed... After the third coat dried, I sanded it down and would be ready for primer if i didn't have to apply filler on the seams that caused me to do all this extra work.. I am using bondo to take out the flat spot on top and blend the ring better.. The EK and glass pretty much took care of the ring, but I just want to be sure...
Oh, besides having no odorclean up with this product is awesome as well.. The extra I had poured out went back into the bottle and my brush cleaned right up with water.. I really don't think I will ever glass with epoxy resin again, I liked it that much... With ER there is no way I could have did 3 coats as fast as this, a couple hours and it's ready for primer, pretty good stuff..
ID:	1785829   Click image for larger version
ID:	1785830   Click image for larger version
ID:	1785831   Click image for larger version
ID:	1785832   Click image for larger version
ID:	1785833   Click image for larger version
