ORIGINAL: BiggerDanno
Higher ABEC ratings (numerically) do not mean that the bearing will spin faster nor with less drag. They are a tighter fit bearing with less clearance between the races and balls. Less clearance = more drag. Less clearance also means better precision and is why the highly rated bearings are used in precision instruments. It amazes me what some people will post!
BTW, I'm a mechanical engineer that specifies the correct bearings to be used in the machines that I design.
+1
+1
