RCU Forums - View Single Post - KingTech K-80
Old 07-27-2012 | 03:44 PM
  #992
megafly
Default RE: KingTech K-80
Hi guys I need a big help over here, I tried today to star my new k80 but it won't start at around 12.000 rpm the engine puts a lot of flames and gets very hot, I stoped two starts atempts at around 780 degress celssius.
Here's my start parameters.
What do you think?
Pump start point Auto +2
Pump start ramp 002
Glow plug power 7.2v
Low Batt Volts 7.0v
Starter Power at ignition 080
Starter power at fuel ramp 110
RPM 100% starter power 18.000rpm
RPM OFF starter 22.000rpm
RPM to reconnect starter 20.000rpm
RPM ignition 3.000rpm
Pump Ignition 025
Engine min flow 050%
EGT end preheat 120 degrees
RPM preheat 5.000rpm
RPM fuel ramp 10.000 rpm
Preheat fuel 45%
Ignition Timeout 27s
Start mode Auto-Kero
This settings are factory setting, I didn't touch it.
Fuel Pump is MTH
Battery is a Lipo 2s 4.000
Thanks for the help.
