RE: Stihl Engine
I've done one of these. The mag is mounted in the case so I'd advise going EI with it. You can use a bennett style muffler as they are a good match on the bolt pattern with just a small amount of work. The real problem is the hub. It will have to be custom made. See if someone here is willing to make ya one.
