RCU Forums - View Single Post - Engine Mount dimensions needed for OS FS 155-a
Old 07-28-2012 | 07:15 AM
Eindecker_pilot's Avatar
Eindecker_pilot
Default Engine Mount dimensions needed for OS FS 155-a
Hello,
I'm building an airplane that will use the OS FS 155 four stroke engine. Because I'm at the part of the build where I need to install the firewall, I would like to know the dimensions of the OS engine mount that will go with this engine & which engine mount part number is compatible with this engine.
From the OS website, I was able to find the dimensions of the engine's mounting lugs.
I think OS part number 71904200 is the right mount for the OS FS 155 four stroke engine. Is that correct? If so, what is the distance from the back of the mount (where it will contact the firewall) to the first pair of engine bolt holes?
thanks,
Greg
