RCU Forums - View Single Post - Goldwing 50cc Pitts Python V3.
Old 07-28-2012 | 07:29 AM
  #128
gjhinshaw's Avatar
gjhinshaw
My Feedback: (303)
Default RE: Goldwing 50cc Pitts Python V3.
Jimbo,
MAN THAT LOOKS GREAT!!! On the Smart-fly, Be sure to beside if you want the power EXSPANDER or the power SYSTEM.... Yes, there are 2 different types! Exspander is UNREGULATED and the SYSTEM is regulated. I go wit the System as its regulated to 6 volts. You can also use the pin-Flag or the Slider switch to shut motor down. I had a DLE 55 on mine and was running a Zoar 21 x 8...... We can NOT run it wide open, BUT what it does do is helps the break-in a lot nicer and you are NOT overloading the engine ANY!! It had INCREADABLE PULL at half stick!! So I decided to just stay with that prop EVEN after break in, It was just that good!! Let me know if you need anything else..... ALSO, Your stuff should ship mid Aug. is what they are telling me......
CHEERS!
Gerry
