ORIGINAL: gjhinshaw
Jimbo,
MAN THAT LOOKS GREAT!!! On the Smart-fly, Be sure to beside if you want the power EXSPANDER or the power SYSTEM.... Yes, there are 2 different types! Exspander is UNREGULATED and the SYSTEM is regulated. I go wit the System as its regulated to 6 volts. You can also use the pin-Flag or the Slider switch to shut motor down. I had a DLE 55 on mine and was running a Zoar 21 x 8...... We can NOT run it wide open, BUT what it does do is helps the break-in a lot nicer and you are NOT overloading the engine ANY!! It had INCREADABLE PULL at half stick!! So I decided to just stay with that prop EVEN after break in, It was just that good!! Let me know if you need anything else..... ALSO, Your stuff should ship mid Aug. is what they are telling me......
CHEERS!
Gerry
Gerry,
thanks a bunch, I know getting them to take care of us in the US is like pulling teeth...
Picked up all my wires and other things yesterday, after flying tomorrow it's shop time... Glad to here on the DLE-55, I am also using the Zoar on mine.. Went a bit bigger for break in, 22x8 and also picked up a 23x8.. They sure do make a nice prop for the money don't they... Thanks again for getting Gw to take care of it and letting me know..
Jimbo
