RCU Forums - View Single Post - Corehouse Li'l Hacker
Old 07-28-2012 | 05:51 PM
paw080
Default RE: Corehouse Li'l Hacker
ORIGINAL: Godsey
I picked up some balloons today. I am going to see if I can work up a pressureless system. I have an idea on how to do it.
Hi Godsey, If you prop your TD for RPMs correctly, you'l use as 5X3 prop. The Lil Hacker is capable
of G forces that will ruin a suction system delivery. You do need to run the TD on pressure when
flying a well designed 1/2A combat model....you really have no choice. So check on any Combat
forums that you may find, and ask how to make and use a pressure fuel system. All of us old
retired Combat flyers learned by asking the appropriate person. You may have to mail order the
components such as rocket tubes, 1/32" wall 3/16" OD surgical tubing and a set of forceps
to pinch off the fuel flow. Almost forgot; a fuel syringe.
Tony
