Hello,
I've got a question for you. I'm trying to get the Futaba S9650 servos in the elevator halves, but haven't managed to yet. I filed the servo bay in one of the halves about a milimeter each side lenght-wise, but the servo still doesn't fit in there. Should I file out around half a milimeter more each side and get closer to the pre-drilled screw holes, or use another method of inserting the servo? Should I just push it straight in there or I'd have to tilt it to one side so the cable goes in first?
My other thoughts are about the servo horns used on the plane. The ones from Dubro with 3/4" (~19mm) distance from the servo shaft center to the hole are recommended for the ailerons and, I believe, for the elevator. Wouldn't this induce too much throw (more than 20-25 degrees)? Has anyone used a cut S9650 four-sided horn (
like one of these)? I'll be using Futaba S9650 servos for the elevator halves and Futaba S9551 servos for the ailerons.
Also, is the double-sided horn in the Dubro package alright to use for the rudder servo horn?
I am aware that Dubro horns are a little sloppy on the Futaba servo splines.
Some servo installation photos would be very appreciated.
Thank you in advance!
Nickolay
