RE: Club Laser?
Ok just took one of the cylinders off my laser 150 v twin. It's in a really bad state. Lots of castor everywhere never seen an engine so bad. I managed to get the most of it apart. The head is sitting in some old fuel to dissolve the castor that I could'nt scrape off. Going to try and get the valves out enough to clean them and the port it was almost closed up with the castor. I really waanted to take the piston off the conrod but it is either glued on with the castor or it is a compresion fit onto the wrist pin. Does anyone know if I need to heat up the conrod to get the pin out ? Rings were also stuck onto the piston got 1 off but I broke the other trying to get it off the piston. Very cool piston with the middle machined out. Got to say though doesn't look like it has alot of wear for a 27 year old engine. Had alot of use though. I think a new set of rings and bearings it'll be good to go for another 27 years. Cams look good and conrods feel good too.
