RE: First timer
Just take it slow and steady don't get in a hurry, you want it to be fun not a job. Look at any and all builds for similar aircraft on RCU before you start. I have borrowed some of my best ideas from this forum. And the most important thing start a building thread here! You will get a lot of support to help build you confidence as well as valuable input as you go. Things you may not have thought of will spark the memories of the members following your build. In the end it is up to you to decide whether to use a suggestion or not, in the long run you have the potential to get a better built airplane. Good luck!
Mike
