RCU Forums - View Single Post - does such an animal exist?
Old 07-31-2012 | 06:12 AM
  #43
SrTelemaster150's Avatar
SrTelemaster150
Default RE: does such an animal exist?
ORIGINAL: JariV
Surprisingly an ASP 400 (5-cyl) has the smallest outer diameter of the bigger radials with a good enough fill volume (220mm dia). I just dont know about the quality of ASP. Their carburetors are almost useless so a good OS or Saito carb would be mandatory purchase for that engine. It would also look good to equip the Hughes with a high pitch 4-blade prop eventhoug a fourblader is not ''correct''. That would allow the user to not spin the engine too fast. The lower the rpms in a radial the better it sounds when it needs to use the torque. Prop sound would tone down and aid the fuselage whistling also. Good place for some serious goosebumps
The ASP is not AAC & is a real boat anchor. I didn't suggest it because of the weight issue. The "quality" is hit or miss.
