RE: How to convert an ATX power supply to rc use
Hi Again , forget to tell my power supply spec , mine one is
Enermax 350w
+3.3v 32a
+5v 32a
+12v 26a
Use 10ohm 10watt resistor on the 5v side and attach on a piece of big alu heatsince , size is 16cm x 10cm x 4.5cm without fan .
Supply power w/o load 12.3v amp unknown not measure yet , but soon .
Supply power w/load 12.15v watt unknown not measure yet , do it soon .
The charger that I use is HK quattro 4 x 6 200 watts
50 watts per ch
I charge all my battery from 7.4 to 11.1v without trouble and power keep on steady and normal , no over heating no burning resistor , everything work just find .
But I need someone to teach me how to install the amp meter and volt meter , so that I don have to use the test meter everytime , hope someone can give a helping hand . tks
