6XAS transmitter
Two questions on this system.
1st what is required in order to allow cycling of the trans. batteries without deconstructing the radio? I have an accu-cycle plus that I use for rec. Batts. I have been told that the company must remove a diode in order to allow this to work.
2nd can the Nicad batteries that came with the radio be replaced with NiMH packs and which packs are OK to use as replacement.
Bowmaker
