RCU Forums - View Single Post - Could this be the perfect clear coat?
Old 08-02-2012 | 09:08 PM
countilaw's Avatar
countilaw
Default RE: Could this be the perfect clear coat?
Strange thing about clear. There is no light going with it. You must apply it heavy enough that it flows together and flows out to a nice shiney gloss, yet light enough it doesn't run.
That's why we call it a "controlled run" when apply clear coat to a car.
Napa auto parts carries a paint that is called "Wanda". It is made by Sekkins in Argentina. This is the same paint that is used on the exotic automobiles.
A gallon goes a long way and it's not really expensive. You can also brush it on bare balsa and use it as a sealer.
Frank
