There is no doubt that Andrew had a advantage his advantage was hard work and,(preparation) and he knew his equipment. I bet he knew what to expect in Muncie and planned his setup for the possibility of any condition.
The guys who wins, is the guy who knows the limitations and advantages of whatever equipment he uses.
I can tell you this, there will be a mass migration back to Glow for the simple fact that Glow power has the advantage of throttle flexibility. there is no denying this . In FAI, Presentation, Grace and constant speed in all conditions play a major roll in putting up a top flight consistantly. The only time Brett even went to full power was on the last flight in the 30mph winds.Having said that, our speed did not change just the Energy we flew with.
Chip did a great job managing his setup in the conditions Better than anyone else could have, giving the same setup and conditions.
But there was no denying the direction he has to go to keep pace, I know he is already making plans
Power flexibilty and the ability to adapt to conditions without harming equipment is the key in a top set up,
Not the Cost, or what Joe blow is running. This ,takes a top pilot to determine. Being able to fly P with any set up is intended for
enclusive involvement of competitors. But,Seperation of the "Top Guys" takes a pattern that stretches the Equipment, Pilot, Caller, and challenges his preparation and skill, No matter what conditions or patterns are thrown your way.
Tha`st why they are innovators in the Hobby and set the direction of the sport when it comes to Equipment.
You can Bet Both Camps will be making adjustments to the Equipment after seeing whats involved in flying the new unknowns in any conditions. No top competitor likes surprises!
But only preparation and knowing the limitation of your equipment ,prepares you for the unknown..
Bryan
