ORIGINAL: celica49
I know at some point i will have to learn that, but in the quick meantime will the set up I posted work? Do the banana clips plug into the battery itself, and then whatever lead is on the other side of the banana clips plugs into the car? Like I said i am brand new to the electric side of things and want the ''shortcut'' if at all possible.
My apologies, I see now that the battery you link to is easy to swap plugs into, so in general what you're suggesting will work.
In looking at the battery, it takes 4mm plugs. The TowerHobbies lead you linked to is 4mm, so yes, that should work! Should be easy for you.
