RE: Elevator Trim Issues
I missed that Balsa just covered with covering. That would really create a problem. Both sets of mine are getting glassed with 1/2 ounce cloth using Deft Sanding Sealer then I will be using 5 ounce glass on the floats bottom using finishing resin just to add a bit in case of gravel and rocks. Balsa is almost as good as a sponge to absorb water.
