RCU Forums - View Single Post - going elec need advice
Old 08-04-2012 | 07:44 AM
speed is life's Avatar
speed is life
Default RE: going elec need advice
Any previous high power electric experience? I ask because 90mm 4000+ watts in a larger model<span style="-webkit-tap-highlight-color: rgba(26, 26, 26, 0.296875); -webkit-composition-fill-color: rgba(175, 192, 227, 0.230469); -webkit-composition-frame-color: rgba(77, 128, 180, 0.230469); ">is really pushing the capability of the power system compaired to 100mm and larger.</span><div><div>Pretty specialized application but works great for those experienced with it.</div><div></div><div>iMO the sweet spot power-weight would be 100mm, 110mm or light weight 120mm. The 127mm size can bulk up pretty fast.....</div><div>
If you are truly into a turnkey solution you can't go wrong with a BVM.........just some duct mods.
</div></div><div></div>
