RCU Forums - View Single Post - Could this be the perfect clear coat?
Old 08-04-2012 | 09:19 AM
countilaw's Avatar
countilaw
Default RE: Could this be the perfect clear coat?
This little item will work for you. You mix your paint and pour it into the glass jar. Then spray your plane like you would with a rattle can.
http://shop.preval.com/collections/preval-sprayer
You also get these at Home Depot.
This is a cheap system to operate. And you can spray latex with it.
Get the 6 oz glass jar and mix your clear with the activator and spray your plane. Let the clear dry for 15 minutes and spray another coat and repeat again for a third coat. Then clean the glass jar with with lacquer thinner and spray some clean lacquer thinner through the system.
Any place that you can spray with a rattle can, you can spray this.
Frank
