RCU Forums - View Single Post - Elevator Trim Issues
Old 08-04-2012 | 12:06 PM
dasquirrelisme
My Feedback: (81)
Default RE: Elevator Trim Issues
My Kadet Senior had the same problem. If the balsa pushrods arent braced they start to bend under pressure. If you put all up elevator and push down on the elevator you will probably notice that the pushrod is bending. I went into mine and braced it but if I did it again I would use different pushrods or make them out of a hardwood dowel instead. Also make sure the wire part is not bending either.
