RCU Forums - View Single Post - This is odd...
Old 08-05-2012 | 12:20 AM
86MOmo
Default RE: This is odd...
Silly question but was the body turned around on the frame?
I can't imagine it just changing direction on its own, but I would check the radio settings and verify that everything is as it should be.
If you look at he LCD readout on the side of the controller, the image of the crawler should indicate which is front and back.  The front should always be toward the top of the radio.  Thus, when you select front steer, the front servo should turn.  I've found it does take some tweaking to get the servos to line up accordingly.
Good luck,
MOmo<br type="_moz"/>
