RCU Forums - View Single Post - trimming question
Old 08-05-2012 | 01:05 AM
Rune
Default trimming question
Hi
I have a Spark that flies just great but have one problem.
the Cg is set around ~25-27% depending wich battery I put in , mixing is at minimum , some trothel to elevator some rudder to aileron and a smal mix from rudder to elevator.
In the trialgel in P13 I have some problems the first leg (that I think its normal) it need to be held so it not dive, the second its up to me to fliy it nice but the last leg it pitches upwards I tried yesterday to let go off the elvator to see if I put in some but still it climbed before and after the roll.
Is it my CG that are to much forward, I have moved the battery a bit forward and backward but no big re****.
The indience og stab is 0 as it should be the wing is about 0.5 positive and thrustline are set to get it to go straight in the uplines.
