RCU Forums - View Single Post - Sig Koverall Application Process
Old 08-05-2012 | 12:20 PM
jester_s1
Moderator
Default RE: Sig Koverall Application Process
A number of people use water based polyurethane now with good results. The advantage is that it is low fumes so you can use it in a fairly confined space. The disadvantage is that subsequent coats do not rewet the ones underneath once they are dry, so fixing mistakes could be harder.
