ORIGINAL: JariV
SrTelemaster, regarding the Moki conrod offset; the two opposite slave rod big end pin locations are closer to each other than the other pins on the same base circle. So all pistons have the same stroke, only two of the pistons move in slightly different ''rhytm'' than the other three.
OK, I see. 3 cyliders (the master & 2 adjacent slave rods 5-1-2)are equally spaced as far as degrees while the remaining 2 (3-4)are spaced a few degree closer W/the widest gaps between 2-3 & 4-5.
That's how they are getting the Harley "V" twin "lope" effect. Several different degree patterns per cycle.
Me likey!
