RCU Forums - View Single Post - Welcome to Club SAITO !
Old 08-05-2012 | 02:55 PM
  #22874
SrTelemaster150's Avatar
SrTelemaster150
Default RE: Welcome to Club SAITO !
ORIGINAL: blw
ORIGINAL: SrTelemaster150
ORIGINAL: Cougar429
rcflyboy, the crock pot and glycol will do an amazing job if left long enough.
So willan overnight soak in Dawn Power Dissolver followed by a hot water rinse then a soak in vinegar to nuetralize it..
That is too long for some aluminum. You have to spot test it past 15 minutes. I've gone 45 minutes on Saitos and Evolutions. Dawn Power Dissolver is wonder stuff, but it can darken aluminum if you aren't careful. I rinse it off by spraying alcohol liberally all over the surfaces. Sounds like you are confusing that with the antifreeze cleaning method.
Not confussing them but you are right, probably more like 4 hours W/the DPD sprayed liberally on the parts laying on a cookie sheet.
The vinegar is a good trick though. The weak acidity brightens up the aluminum & neutralizes the akalinity of the DPD.
