ORIGINAL: MTK
Cap'n, you probably should not use the med tubing. Looks nice but I think you would find the material falling apart after a few months. It's primary use is saline delivery or air delivery
You are most likeley right....I do not use med tubing....for a vent it may work in a pinch. I used new Hayes neopreme line in the gasfuel tankand it did not last a week. The rest of the line I use on a hand crank gas pump....works fine for that because the fuel is not in it only when using thepump. Capt,n
