ORIGINAL: opjose
To anyone who is using Max's kit...
How is the sensor ring supposed to be mounted?
My sensor ring does not look like the one in the instructions Max e-mailed me.
Worst still if I orient the ring as per the instructions with the ''adjustment screw'' facing straight up in relation to the head, then the ring is restricted by the carb mount...
See attached picture.
You've got it about 90 degrees off....
Adjustment screw straight up and down like the way the piston travels.
